Old 07-23-2012, 12:45 AM   #43 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by cbaker View Post
6500 rpm! That's where the redline is on the rpm meter. I figured it was just left over from the previous model. I still try not to exceed 40 mph. It's been extremely hot here and I'm not sure of the motor overheating, as well as the rpm spec, if there is one. There is a fan on the controller, but no cooling asistance for the motor. The rpm guage is hooked to the transmission so I have no idea of the real motor rpm. When I slip it out of gear it still goes with the speed of the vehicle.
On this EV they assumed you were always in gear, the stock 2nd gear. So they tied the speedo and the rpms, the RPM guage is very accurate in 2nd gear, any other gear it is wrong. The reason this was needed is there was no cheap easy way to generate a signal for the gas RPM guage off the motor directly so they cheated.
And yes you can go over 40mph in a "higher" gear, you just need to take it easy or play it safe which means you can't drive an extended period of time above 40mph, but if its flat ground, no wind, I would guess 5-10 miles probably wouldn't hurt anything (I have driven that far flat out 45mph without issue on the small motor for above 5 miles each way, but my motor amps were around 100, much higher and I wouldn't have risked it on my tinker toy motor)
If you get an ammeter you can see if your in the safe or dangerous area while at speed. (your big motor should easily withstand about 175amps for approx an hour, not counting acceleration and other events)
So, It is possible you could travel at higher speeds safely, it all depends on how many amps you are burning to go that speed, it also would help if you weighed the motor and posted
Finding a motor on a budget - DIY Electric Car Forums
there with your motor specifics, including its weight.
On a DC motor, weight = HP. More weight more resistance to heating up.
Cheers
Ryan
