Old 07-23-2012, 05:59 PM   #8 (permalink)
seifrob
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Originally Posted by Quezacotl View Post
As soon as i get my Golf repaired, i think i'll do these:
-Replace bulps with LEDs as much as i can/is worth
I would warn from excessive LED use instead of bulbs. Interier is fine, but brake light domes, rear lights domes and turn indicator light domes are designed for bulbs with respect to direction, intensity and colour of light. LEDs usually emit light only in narrov beam, not 180 degrees like regular bulb. If you retrofit bulb in your light with LEDs, you can easily make your signals invisible (at least from certain angles).
