Old 07-23-2012, 11:31 PM   #8 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by turbovr41991 View Post
No problem. I am pretty sure I am right about the transmissions. Feel free to check it out. I bought my CX from the original owner with a bad input shaft bearing. It still ran and drove fine, just ridiculously loud. It was the original transmission as well as the clutch. Having owned several DX and LX civics before, I can say without a doubt this has the VX highly geared trans. In fact I actually replaced the trans with one from a 94 VX. It drives identically.
I plan on improving the areo of the hatchback by adding a Kammback or a tail. Probably Kammback for the short turm.
I just sold a set of VX wheels I had been using. Those wheels were ok, but I dislike the options for 13 inch tires. If you did not know both the Honda VX and HX wheels were both manufactured by Enkei (stamp is on the inside of the wheel.) I am now trying to decide what wheels to use. I have the 14 in HX and some 9.5 lb 15 inch enkei RPF1 wheels. So now I am weighing my options. (sorry bad pun)
As for the condition, I will post pictures later. As stated before, the CX came from the original owner and was 100% stock. It was well maintained and garaged it whole life and still has glossy red paint. Also rust free which is pretty rare over here. I am pretty partial to it.
The HX I bought from the second owner. It is pretty clean but not maintained as well. Completely stock with some rush on the rear quarters and above the windshield (which is odd.) It is also red, but has faded due to being stored outside.
I guess a 3rd option would be to pick up a blown engine sedan and swap over the HX engine with a VX/CX trans into it. Reason being, I have a 4 month old and the car seat would be easier to deal with. Then keep the CX as is as a extra vehicle.
If you have a 5th gen VX (1992-1995) trans in your sixth gen CX (1996-2000), then you do have very good gearing: it should be 3.250:1 instead of the HX's 3.750:1. Swap that VX trans into the HX and use your 15" lightweight wheels and you will have highway cruise gearing taller than the original VX and approaching the 4th gen HF. You could put a Kamm on the HX much more easily than you can swap that HX engine into the VX. But I understand the passion for the better looking car, so if you feel confident and can spend the time, go for it. Have you studied aerocivic's mods to his CX/VX? You could do a lot. Also 3wheeler's insight boat tail -- both are amazing pieces of work.
