Originally Posted by Phantom
It should still translate you could (assuming the dino allows load control) run the car to 80mph with a very small load at stock psi time it then do a 60psi run followed by an 80psi run keeping everything the same. Then you just take the percent change and you will have a repeatable measure that will hold the same for all surfaces under the same conditions as the only change is the psi.
Maybe, maybe not. The dyno machines used by the tire companies use for rolling resistance measurement have very large rollers to minimize the divergence from a flat road. This dyno has fairly small rollers.
In addition, my friend runs his shop FOR PROFIT. I'm not going to ask him to spend an hour or more on some sophisticated test I dream up. He is doing the tests because it is simple and quick. My objectives are much more limited.
![Wink](/forum/images/smilies/wink.gif)
