Old 07-24-2012, 10:22 PM   #11 (permalink)
OurInsight - '06 Honda Insight
Originally Posted by HyperMileQC View Post
Unrelated to the belly pan, Is your battery sytems and regeneratives fonctions still working on your 2006 Honda Insight?
Last time I saw it, everything was fine. It has been in the shop for minor collision damage for about 5 weeks. "Any day now."
Old 07-24-2012, 10:43 PM   #12 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Originally Posted by jimepting View Post
I was out just today surveying a possible test route.
I meant: I thought your dyno news was to test tire pressure. Can't get much more controlled than that!
Old 07-24-2012, 10:49 PM   #13 (permalink)
It isn't obvious to me that that is a test of rolling resistance or fuel economy. The dyno rollers are only about a foot in diameter, so the tire contact patch is completely different than street conditions.
I'm just trying to get a comparrison between two cars, one rather old and the other fairly new
Old 07-24-2012, 11:13 PM   #14 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
It should still translate you could (assuming the dino allows load control) run the car to 80mph with a very small load at stock psi time it then do a 60psi run followed by an 80psi run keeping everything the same. Then you just take the percent change and you will have a repeatable measure that will hold the same for all surfaces under the same conditions as the only change is the psi.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 07-25-2012, 07:25 AM   #15 (permalink)
Maybe, maybe not. The dyno machines used by the tire companies use for rolling resistance measurement have very large rollers to minimize the divergence from a flat road. This dyno has fairly small rollers.
In addition, my friend runs his shop FOR PROFIT. I'm not going to ask him to spend an hour or more on some sophisticated test I dream up. He is doing the tests because it is simple and quick. My objectives are much more limited.
Old 07-27-2012, 11:11 AM   #16 (permalink)
Dyno Testing
Ok, the dyno testing on my silver Insight is done. I posted those results over on InsightCentral at this link:
Dyno Testing on My 2001 Insight - Insight Central: Honda Insight Forum
since it seemed more Insight specific. The car is down a bit on power, but not so much as a chassis dyno makes it appear. Looks like the VTEC isn't actuating.
I'll be posting my underbelly pictures, which I was able to get on the York Automotive lift, here soon as a get a few spare minutes.
Old 07-27-2012, 05:29 PM   #17 (permalink)
Underbelly Pictures
Here are pictures of the Insight underbelly, front and rear, which are a mix of aluminum at front/back and coroplast in the midsection.
Took one long trip and I think it helps, but the Insight is damnably difficult to test anything on. Though the underbelly helps in itself, the work is anticipation of a boattail which I hope to build over the winter.
Old 07-27-2012, 05:54 PM   #18 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
How much room did you leave for the air to flow out of the engine compartment?
Old 07-27-2012, 06:57 PM   #19 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
I am surprised that the leading edge didnt get pulled. It looks like it is exposed, am I correct?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-27-2012, 07:59 PM   #20 (permalink)
There is considerable outflow area into the wheel wells which is a near ideal flow according to Hucho. In addition, there is flow down the center tunnel. I took a long hot trip yesterday while returning from my dyno session and the intake air temp., the only real measure I have from under the hood, remained in a near perfect range. I think there is enough flow.
