I'm not sure if the question was ever answered: "What values are you looking at?"
If speed and odo-distance are accurate, then your VSS & config are good.
If only speed OR odo is good, and the other bad, then i guess the crystal MHZ could be a factor, but only if the values are wrong by 25%.
