Old 07-26-2012, 01:34 AM   #9 (permalink)
MGB=MPG
Smooth Operator
Old Yellar - '79 MGB Tourer Drop-Hood Coupé
Sports Cars
90 day: 25.83 mpg (US)
Old Brown Ford - '91 Ford Bronco Custom
MAGNUM - '05 DODGE MAGNUM SXT
possible hazards
emphasis
""Keep an eye on the temperature gauge when doing mods like this"".
your fairing mods seem quite smooth and *apparently* show reduced drag.
i have thought about putting some blocks in similar to your uppers , however i feel they should be adjustable louvers [flappers] ideally opening anytime the cooling fan kicks on , manually operated *could be* adequate , if the operator remembers to open them when needed for cooling
200F operating temp is ok , i have 195F thermostats in my machines , i presume the small ducts allow road air in to the radiator , which may work adequately at road speeds, however overheats are more likely at a stop or at very slow road speeds , when you have to depend on the fans for cooling air ..
