Old 07-28-2012, 08:30 PM   #464 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Smoothed Streamlining Template
Phil,
After working with the CAD for a few hours, it became apparent that some more extreme radii would allow a nice rendition of the streamlining template.
This first graphic shows the use of 4 radii, namely 3.75H, 7.5H, 15H, and 30H.
Now take a look at the second graphic.
Several things are obvious from this.
First, either my math is off or the template, in it's current form is not drawn 5:1 in length.
Also, the 30H radius is drawn at an ending angle of 22°, just as you have mentioned as the maximum angle that the template should show.
There is probably a mathematical function, or a wing design program out there on the web that would model the streamlining template better than what I have shown here.
Jim.
ID:	11269   Click image for larger version
ID:	11270   Click image for larger version
ID:	11271   Click image for larger version
The Following User Says Thank You to 3-Wheeler For This Useful Post:
BamZipPow (07-29-2012)
