Old 07-30-2012, 12:48 PM   #39 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by suspectnumber961 View Post
1) warm air intake was not an issue....since intake air was already being drawn from under the hood with previous setup
Without knowing what temperature air was being sucked into the engine, this conclusion cannot be supported.
2) warmer ambient temps not a factor due to not using AC and driving usually in temps under 85 F.
The effects of air temperature cannot be modeled as a switch. That is, one cannot state that below a given temperature (say, 85 F), air temperature will behave one way, and will behave another way when the air temperature goes above that given temperature.
3) it's possible that I was trying a little harder with the driving techniques
This gain might have been caused by warm air being sucked into the intake. This gain might have been caused by removing a restrictive stock intake housing. This gain might have been caused by more attentive driving. This gain might have been caused by a combination of all 3 factors. Or this gain might have been caused by something else entirely. But we will never know for certain, due to the shoddy nature of the performed testing.
4) with the last refill...the gallons used was close to right on...so the need to readjust gallons used DOWN as seen with previous 2 refills was not seen this time
Huh?
Is this the same as a correction factor applied to the odometer reading, to get a more accurate measure of miles travelled?
Basic science? ...try something to see if it works....THEN try to explain it? Don't try to explain it before you try it?
Blindly do something without understanding the underlying principles? Conduct tests while leaving so many variables open that the test results are meaningless?
While you (?) can still argue about it for whatever reasons...understand that I'm still seeing a 6.7% mpg gain. So there....
This does not help the cause of ecomodding. One might as well do the same thing with fuel magnets.
The Following 2 Users Say Thank You to t vago For This Useful Post:
mcrews (07-30-2012), niky (08-01-2012)
