Old 07-04-2012, 03:07 PM   #31 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by suspectnumber961 View Post
My only responsibility here (and I use that term loosely) is report something that I think might be increasing my mpg...not to argue endlessly as to how many angels fit on the head of a pin.
So you have no problem with making unsubstantiated and possibly wildly inflated claims of fuel economy. You'd be perfect for selling fuel magnets.
Old 07-04-2012, 04:21 PM   #32 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Althought Fuel magnets actually work !
(i'll get my coat)
Old 07-04-2012, 05:31 PM   #33 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
(i'll get my coat)
oh please..........
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 07-04-2012, 11:07 PM   #34 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
do not BS me lad - because i see it
"EDIT: We didn't attach an OBD reader to the car... but there was little need and no time to do a comprehensive test... it's a relatively simple car with a single cat that doesn't meet US or Euro emissions standards, so any computer chicanery is happening due to what's going on at the MAP and not the O2 sensor... especially since we weren't running it in closed-loop on the dyno (all WOT runs).
very pretty
but you have not attributed any values to any of the pretty little lines on your graphs which may or may not be related to the blarney you are posting -
so
you follow the
if you can not dazzle them with brilliance , baffle them with BS .
the alleged test mule is not in "closed loop" and meets no EOBD or OBD2 standards as such - how do you suppose this has anything at all to do with what you imply ?
it does not .
try again
no more BS
you do not need a dyno in fact for real cars driven on the street
dynos do not and cannot reflect real conditions - like this - see calculated load
if you do something / anything to improve this exact system on this exact car - the calculated load value will increase when driven under the same conditions shown in this screen cap
you claim x% at wot
- your claim would be reflected or disproved by calculated load
show me
Old 07-05-2012, 01:11 AM   #35 (permalink)
very pretty
so
you follow the
it does not .
try again
no more BS
you claim x% at wot
show me
I try to be nice...
I don't know what you think I am saying, but what I am saying is that these are power gains and losses shown on a car at full throttle under load on a Dynapack dyno.
Under load means it is pushing against the brakes of the dyno, which measure the force exerted against them.
That the car is at WOT and not in closed loop is important because somebody said the computer would readjust itself in milliseconds. Which is both true and not true.
Some computers adjust right away (again... turbodiesel, cone filter... no gain)... some don't. Those that don't adjust can still adjust if the AFRs at the O2 sensor wander far enough to cause the computer to adjust... but that won't happen at WOT, it will happen in closed-loop at part throttle. Which we were not testing... And it takes time for LTFT to wander. Also, taking OBD readings off the stock narrowband is nowhere near as accurate as using a wideband. Yes, there are issues with using a wideband shoved up the tailpipe as opposed to plugged into the exhaust manifold (my exhaust, for example, throws off tailpipe readings), but it will still be more sensitive than the stock narrowband O2.
A dyno is not real world conditions... I absolutely agree. But a dyno is a repeatable, stable test wherein you can control load, speed, temperature (if you've got enough fans) and other variables. You still can't control for humidity given our settings, and SAE correction factors are often inadequate when testing out modern cars that actually adjust themselves for ambient temperature and air pressure (see the brouhaha over the R35 Nissan GT-R dyno-tests when it first came out, non-SAE corrected, it often made the same HP in various conditions on similar dynos... apply SAE corrections, you got wildly different outputs... because the GT-R ECU alters boost levels based on atmospheric conditions, as can be seen by the boost traces on those dynos).
There are no headwinds or tailwinds on the dyno. Throttle position and how aggressively you start your "sweep" are still an issue, but you can control that by doing braked point tests instead of a sweep. There is no tire slippage on a Dynapack, no effects of tire pressure or rolling resistance.
It's just a simple measure of how much torque an engine can transfer through the driveaxles into the brake. There is some argument as to how accurate each dyno is, as they all read differently, and endless arguments over best gear-ratios to use when dyno-ing (should get as close as possible to 1:1, but that's not always possible), but here, we're only interested in the difference caused by the part being tested.
If all cars responded to all air intakes in the same way, and if all aftermarket air intakes were bogus, companies wouldn't be spending thousands of dollars researching new intakes and trying to find ways to make more "bogus" power with them.
As for values:
The steady blue line trace is stock power and torque measured on the brake via a sweep test at full throttle. No SAE correction or Torque Correction Factor applied. (TCF is bull, anyway... since it's an assumed, operator entered number).
Ratio and roadspeed are operator entered and not accurate. Again... this was done as a "before and after" preliminary test to see if it was worth building an intake for the car, so we weren't concerned with actual road speed or gear ratios, just the before and after traces for power. The incorrect gear ratio doesn't mess up the torque-to-hp calculations, since the dyno reads rpm off the ECU and does those calculations internally. Besides... again... we were only interested in before and after traces.
The three sweep lines with the irregular peaks are with the intake.. and show obvious gains at low rpm and high rpm, with an obvious dip in the middle.
Again, not shown are where we bolted the stock box back on and did a few sweeps. The gains and losses in each area were exactly halfway between stock and modified. The operator didn't think to save those traces at the time.
Would it have been instructive to attach an OBD reader to see this phenomenon happen on the road? Of course. Was it my job to do so and did I have time to do so? No.
I'm honestly baffled by what your issue is. All I've said previously is that intake modifications nowadays are voodoo simply because the computers seem to either adapt to them or not according to their own whim, and that this particular car gained power in some places and lost power in others, seemingly due to some weird intervention by the computer. And that I've seen some MAP-equipped cars that could dial back power completely from an air-filter change... Could it be very specific resonance tuning involving the intake resonator? Maybe. Would more testing tell us for sure? Probably.
I don't see how this, in any way, is bull. I'm not selling any snake oil here, just sharing what I've seen. Intakes are weird. They sometimes work and sometimes don't, and not always for the reasons you think they will or won't. And that's all there is to it.
Perhaps your issue is where I said a fuel economy change was believable with a MAF-equipped car (which the car in the dyno doesn't have). I say that because MAF-equipped cars are sensitive to turbulence or tubing or positioning changing the senor readings, and what we've noticed is that air filter position can play a role in gaining or losing power. some guys have even resorted to putting small mesh filters in front of the MAF to smooth out the air at the sensor... and in testing, the shop will sometimes try out multiple MAF positions to find out what works best.
While I say this is believable, I am not a believer in changing out your air filter to increase fuel economy. It could just as easily make it worse. Or not do anything at all except give you less filtration than stock for no increase in power or economy. And if there is an increase in economy, it may eventually get lost if the ECU readjusts. It would be much better to retune the car simply so that the usually overly rich fuel tables in the ECU are dialed back to more realistic levels.
Oh... and... please be nice.
Old 07-06-2012, 07:32 PM   #36 (permalink)
affect
Originally Posted by HydroJim View Post
I'm not saying that the gains suspectnumber961 is experiencing are accurate, but I feel that the rest of you guys are too quick to turn it down. I understand the need for accurate testing and I want it too.
The factory air intake set up on a ford Focus is very long, winding, and restrictive.
a short-ram intake like the one installed in this case may actually be producing a gain on this particular car. I'm not saying it's the filter itself, I'm just saying that on this particular car, this mod seems to help. Countless people swear by MPG gains from air filters like this in focus based forums, so there may be something to it.
t-vago- The ford focus uses a MAF sensor so warm air intakes have no affect.
Again, I'm in no way endorsing or refuting the gains, I'm just trying to find an explanation
It would be very helpful for someone to install pressure taps along the entire inlet tract,feeding a bank of Magnehelics or manometers,and photograph a pressure histogram under real road load conditions for which to compare before and after.
Old 07-30-2012, 08:12 AM   #37 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Thumbs up
* 3 tank avg of 37.35 mpg concludes an A-B test of a cone filter for a 6.7% mpg gain from last summer's ~35 mpg avg.
notes:
1) warm air intake was not an issue....since intake air was already being drawn from under the hood with previous setup
2) warmer ambient temps not a factor due to not using AC and driving usually in temps under 85 F.
3) it's possible that I was trying a little harder with the driving techniques
4) with the last refill...the gallons used was close to right on...so the need to readjust gallons used DOWN as seen with previous 2 refills was not seen this time
Basic science? ...try something to see if it works....THEN try to explain it? Don't try to explain it before you try it?
While you (?) can still argue about it for whatever reasons...understand that I'm still seeing a 6.7% mpg gain. So there....
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 07-30-2012, 09:59 AM   #38 (permalink)
mcrews's Avatar
1. That is NOT an a-b test. please.
2. Since you have no idea what a basic a-b test involves, then your result is not believeable.
If you want to post that your log showed a different result from last summer....fine.
But don't think you can call that an a-b test. That really calls to mind......bs.
The ENTIRE point of a-b-a testing is to control the variances as much as possible by doing the test here comes.........
[U]SAME TIME OF DAY
SAME CONDITIONS
HELLO!!!!!
U]
ECO MODS PERFORMED:
First: ScangaugeII
The Following 2 Users Say Thank You to mcrews For This Useful Post:
niky (08-01-2012), t vago (07-30-2012)
Old 07-30-2012, 12:48 PM   #39 (permalink)
MPGuino Supporter
t vago's Avatar
Without knowing what temperature air was being sucked into the engine, this conclusion cannot be supported.
The effects of air temperature cannot be modeled as a switch. That is, one cannot state that below a given temperature (say, 85 F), air temperature will behave one way, and will behave another way when the air temperature goes above that given temperature.
This gain might have been caused by warm air being sucked into the intake. This gain might have been caused by removing a restrictive stock intake housing. This gain might have been caused by more attentive driving. This gain might have been caused by a combination of all 3 factors. Or this gain might have been caused by something else entirely. But we will never know for certain, due to the shoddy nature of the performed testing.
Huh?
Is this the same as a correction factor applied to the odometer reading, to get a more accurate measure of miles travelled?
Blindly do something without understanding the underlying principles? Conduct tests while leaving so many variables open that the test results are meaningless?
This does not help the cause of ecomodding. One might as well do the same thing with fuel magnets.
The Following 2 Users Say Thank You to t vago For This Useful Post:
mcrews (07-30-2012), niky (08-01-2012)
Old 07-30-2012, 09:41 PM   #40 (permalink)
mcrews's Avatar
t vargo,
thank you for taking the time to debunk each item calmy..........
ECO MODS PERFORMED:
First: ScangaugeII
