Old 08-02-2012, 06:45 PM   #135 (permalink)
JethroBodine
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
My 20.45 mile commute route is probably as good as it gets for P&G and EO(ff)C, especially on the way to work. With the gas engine, I RARELY ran the engine enough to reach the thermostat opening temp, even when I made trips during the day at 90 deg.F. I was using as little as .15 gallons for the trip to work. Highways around here are long uphills( 1-3 miles) followed by nearly the same down hill. Getting up those long hills burns a lot of fuel, and I would get worse mileage on the highway route.
Aero does help quite a bit, as I was getting 50mpg on cruise control on the highway just before the swap, better if I went 55 and used EOC. As with Palemalanesian, I keep getting better and better at the off highway route.
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
