Old 08-07-2012, 11:08 PM   #85 (permalink)
sendler
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
There was a significant portion of super highway, maybe 1/4 of the total mileage, which was run at a mild for Vetter conditions 70 mph. I was carrying 60 pounds of camping gear in 100 liters so had more extra weight added to the bike than the empty streamliners. I also believe 100 liters will come close to carrying all the groceries if they were repacked into a greater number of "normal", smaller bags. I have found that adding mass to my bike serves to increase the effectiveness of Pulse and Glide and only becomes a detriment when you touch the brakes. There were a lot of stop signs but on an 80 mile ride they still represent a small portion of the energy that is needed and wasted by the extra weight. The reason the stock bodywork Honda CBR250R was able to nearly match the FE of a streamlined Ninja is due to the fact that it has a single cylinder engine ( smallest combustion chamber surface area vs displacement for less waste heat absorption) with cams (less overlap and duration) and intake runner (long, the Ninja has only a short vel stack?) that are tuned for much lower rpm. Keep in mind also that the CBR has a huge (by motorcycle standards) cat and a closed loop O2 sensor so it has no doubt the cleanest exhaust in the group and a very quiet muffler. It does have a less than ideal, standard bike seat height and pegs though so the door is open for some other bike to be a better starting point for a feet forward streamliner.
I am very comfortable cross country touring in my "touring tuck" which is done by laying my solar plex on a stuffed tank bag to get my shoulders under the windscreen and allowing the remaining wind blast to balance the weight of the helmet. I get great numbers (95 mpgUS on the 440 mile way down from Syracuse to Ohio) this way but most people can't/ won't try it and it goes against the theme of the event where Craig wants to promote a vehicle that everyone will feel comfortable to chose as "first choice in the garage". Another exception being Keith who turned a really great 85mpg on his stock bodied/ long geared Ninja by using a tight tuck. There was a tucked rider on a 600 super sport also but I don't know if he filled up with a slip to turn in as many of the competitors that started, lost their resolve for the tight grouping and fast pace on wet roads after the electric bike wrecked.
The Following User Says Thank You to sendler For This Useful Post:
visionary (08-08-2012)
