Old 08-08-2012, 08:42 AM   #252 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
I like your boat tail. If I had one on my car I could fit my recumbent bike inside. I have used the poly foam used to insulate pipes, slit in hal.f to seal around the sun roof for a plywood antenna stand. I compressed it with wing nuts. If you use a rubber seal, like for a garage door, it will rub and eventually wear the paint any way. If it was fiberglassed, then it wouldn't be removable or flexible. Silicone sealer might work if you used a thin piece of plastic sheet between the roof and tail, though it would be hard to get it off the paint, it could act as a plastic hinge.
- Tony
