Old 08-08-2012, 07:00 AM   #251 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by Weather Spotter View Post
You know what's missing? 'Home Sweet Home' hanging on one of the sides
Looks great!
Old 08-08-2012, 08:42 AM   #252 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
I like your boat tail. If I had one on my car I could fit my recumbent bike inside. I have used the poly foam used to insulate pipes, slit in hal.f to seal around the sun roof for a plywood antenna stand. I compressed it with wing nuts. If you use a rubber seal, like for a garage door, it will rub and eventually wear the paint any way. If it was fiberglassed, then it wouldn't be removable or flexible. Silicone sealer might work if you used a thin piece of plastic sheet between the roof and tail, though it would be hard to get it off the paint, it could act as a plastic hinge.
- Tony
Old 08-08-2012, 12:37 PM   #253 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
What I have now is the foam pipe insulation and it never sealed real.well. its also about 3/4" higher then the roof right now. So I might redo the 6" closest to the car and foam the last 1/4 inch with backer rod or door dealer then silicone the top edge.
Old 08-08-2012, 08:02 PM   #254 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
At work we us Wurth brand sealer called "Windshield Weld" that seals everything. I could bring a tube with me if you don't mind waiting. There might be a place that sells the stuff around you?
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 08-08-2012, 09:07 PM   #255 (permalink)
Wiki Mod
Jethro, I did do some work on the tail but I never pass up free A seals everything tube might be handy to keep in the work shop for that moment when I need a sealer and do not have one.
Leak update:
since we have rain in the forecast for the next few days, and I do not want to get my nice new wood floor wet, I decided to get some work done on the car when I got home from work.
First I did some detailed examination of where I had issues. Next I decided where I might get away with using caulk and or caulk with backer rod ($4.19 for 5/8" x20'). I marked with red sharpy where I needed to do major work. The top has been annoying me since I built the tail. it never seems to want to say flat at the level of the car roof and sticks up 3/4". this forces water to build up at the joint causing minor leaks to turn in to big ones
I decided this area needed major work so I started there:
Old:
work in progress:
as I expected the foam was being pushed up by the hatch mounts, so when I made a wood piece to fit the hole I shaved down the back side over these spots to make to level.
ready for resin
the second coat I mixed in some sand to thicken the mix and help it fill in the low spot. this was my fist time mixing in anything to resin and it worked better then I hoped.
Done and silicone caulked:
I will have to wait to paint it, and there is rain for a few days so I think I can test it. I pray it will not leak, I sleep better dry
its not perfectly smooth but its better then it was and it should drain water.
The Following User Says Thank You to Weather Spotter For This Useful Post:
aerohead (08-09-2012)
Old 08-08-2012, 09:45 PM   #256 (permalink)
Diesel
Aerohead says that form is better than finish. That works for me. Less sanding.
Boat tail project
Old 08-08-2012, 09:59 PM   #257 (permalink)
Wiki Mod
Who said that banded word for smoothing surfaces ? That's more work then I tend to put into my tail. I just put on the fiberglass, add a second coat of resin and spray paint.
Ok it would look better sanded but then I would spend days doing it only for looks.
Old 08-09-2012, 06:51 PM   #258 (permalink)
Wiki Mod
well we had lots of rain all day. I only had a few drips in the tail!
at lunch I went looking for the cause of the leaks and found that I had 4 places I missed a dab of caulk, once the rain stops I will fix those spots. it also seems that one of my hatch screws was over tightened so I have a 4" small crack in the plexi glass. it has not gotten longer in 6 months and it the source of a small drip. will caulk fix this too? recommendations?
Old 08-09-2012, 07:03 PM   #259 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Drill a small hole just in front of the crack, so it cracks into it. This will stop the crack from cracking further. You could seal it the hole with a small dab of something to keep drips out.
- Tony
Old 08-13-2012, 09:23 AM   #260 (permalink)
When did you add the nose cone? Is there a thread for it?
BOAT TAIL Drag Reduction Estimates aerohead Aerodynamics 12 01-30-2016 05:08 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 10:59 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 11:30 PM
collapsible curved folding 10mm coroplast boat tail miket Aerodynamics 5 08-12-2010 02:58 PM
Subaru Outback Prototype Boat Tail Test Results brucey Aerodynamics 10 10-02-2009 06:03 PM
