Old 08-08-2012, 05:11 PM   #10 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
the rear is narrower by 1.9 inches..........
viper 2002-2006
Wheelbase 98.8 (2,510)
Track, Front 62.9 (1,598)
Track, Rear 61.0 (1,550)
Viper Specifications and Sizes: 2003-2006 and 2013-?2013 Viper specifications, sizes, and such
ENGINE: 8.4-LITER V-10
Type and Description 10-cylinder, 90-degree V-type, liquid-cooled, 8.4 liter
Bore x Stroke 4.055 x 3.96 (103 x 100.6)
Flywheel Low-inertia aluminum with steel wear surface
Intake Three-piece shell molded, vibration-welded composite for improved flow, reduced weight and improved thermal performance
Valve System OHV, variable-valve timing (VVT), 20 valves, roller-type hydraulic lifters
Construction Aluminum-alloy block with cast-iron liners, forged-aluminum pistons, forged-steel crankshaft, aluminum-alloy heads
Compression Ratio 10.2:1
Power (SAE net) 640 bhp (477 kW) @ 6,150 rpm (76 bhp/L)
Torque (SAE net) 600 lb.-ft. (814 Nm) @ 4,950 rpm (the sign on the engine display reads 4,200 rpm and 813 Nm)
Max. Engine Speed 6,400 rpm (fuel cutoff)
Fuel Requirement Unleaded premium (91 Octane (R+M)/2)
Capacity 11 quarters (10.4 liters) of oil, with filter; 16 quarters (15 liters) of coolant
Alternator 180-amp high-speed
Transmission Synchronized in all gears, electronic 1-4 skip-shift and reverse lockout mechanisms
1st 2.26
2nd 1.58
3rd 1.19
4th 1.00
5th 0.77
6th 0.63
Axle Ratio 3.55
Overall Top-gear 2.24
Axle Frame-mounted hypoid bevel gear with GKN ViscoLok speed-sensing limited-slip differential; 3.55:1
Overall Length 175.7 (4,463)
Overall Width 76.4 (1,941)
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
