Old 08-09-2012, 02:27 AM   #15 (permalink)
GTR
Red VX - '93 Honda Civic VX
Teal VX - '94 Honda Civic VX
Godzilla - '09 Nissan GTR Premium
Received the O2 sensor today, it was LZA09. Installed and works great. 95% of all hesitation is gone now. I think there is a small hiccup when pressing the throttle down while the car is idling, but other than that, it drives smooooth now and def has more solid torque under load which is pretty noticeable at low RPM.
I believe oxygensensor.net has all of the correct part #'s for this sensor across all brands. It is what I used to determine the right sensor. Everyone says the Bosch sensor are cheaper, but the Bosch part numbers listed here are 300-500 dollars.
NTK 24300
5 Wire Wideband Oxygen Sensor
NTK L2H2
Replaces the Original 5 Wire L1H1
NTK # LZA-09-E1
NTK Sensor for FAST Classic ECU
Fast # 307000
Honda # 36531-P07-003
36531-P2M-A01
36531-P2M-A02
Motec # 57003
Bosch # 13246
Bosch # 13025
Seems to me if any sensor is < 200 bucks, it was probably the wrong one.
Oh and I should add, the amazon link I posted above is not the same vendor. The sensor I bought came directly from Amazon but it was the last one in stock...so now that part number is pointing at a marketplace vendor selling the same thing. Just an FYI.
Oh and I found this site that had a interesting list of applications for this sensor. I wonder if one could splice in a connection and also use a compatible AF gauge in the car.
http://www.bmotorsports.com/shop/pro...roducts_id/580
NGK Powerdex AFX
FAST Classic ECU [ 307000 ]
FAST XFI ECU
Custom Applications
Accel DFI Engine Analyzer when used with our mating connector - click here for connector
OEM: Honda, Acura & others in some applications
Replacement for ALL L1H1 & L2H2 applications
NTK Part Number: 24300
HKS Wideband - click to see our special HKS sensor with the HKS connector already on the unit
Motec Part Number: 57003 & 57007
Honda Part Number: 36531-P07-003
Honda Part Number: 36531-P2M-A01
Bosch Part Number: 13025 & 13246
Denso Part Number: 2345052
SMP / Standard Motor Parts Part Number: SG335
WBO2.com & Tech Edge Air Fuel Meters
Many Industrial & Agricultural applications using other, more expensive sensors
Works with most wideband controllers specifying an NTK wideband sensor
Honda Civic ( 1992 - 2000 )
Many more applications not listed here
