Old 08-09-2012, 02:28 PM   #15 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Are you just eyeballing the angles or are you using math ?
Once you lay the template over the line drawing ( and have it at the correct spot ), you can simply print it onto a grid and use a yard-stick to scale up and measure the heights you need to be at at a given length.
This is of course with a perfectly level car on a flat surface.
I'm sure you were already using this method, but wasn't sure.
