Changing only the exhaust timing is only possible on twin cam engines wich I believe the SR is not.
Advancing cam is still possible on single cam engines but the potential is narrower since you also mess with the inlet where the valve is lifted just before TDC so you don't want the valve and piston meeting each other ...
