Originally Posted by Daox
It is not possible with a gasoline engine. Gas engines are throttled with the throttle body and air/fuel ratio is kept via other sensors. Diesel engines are throttled with how much fuel is injected and air/fuel ratios are all over the map.
It *IS* possible to run gasoline engines without a throttle plate! BMW does it:
Valvetronic - Wikipedia, the free encyclopedia
Fiat and Nissan also have versions of this.
But it's really not feasible to convert a conventional throttle engine to a valve-throttled engine.
