Old 08-19-2012, 07:31 AM   #3 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Might be able to just use some blade connectors. Attach the wires to the blade connectors then epoxy the connectors to a suitable backing material to keep them spaced to fit the fuse block. Or maybe try cutting the top off the fuse and soldering wire to the blades I'm sure the fuse part will open from the heat.
The Following User Says Thank You to nemo For This Useful Post:
Weather Spotter (08-19-2012)
