Old 08-19-2012, 03:32 PM   #13 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
It sounds like you have just enough smoke to where installing a J-code intake manifold and getting a better air cleaner could clear it up.
If you have fuel leaks your brick style fuel filter is likely leaking, from the filter block.
Or a bad injector to line connection.
Already have a J-code intake on there...
Nah, it will fumigate the neighborhood if I stomp at lower RPMs, I am getting smoke somewhere mid throttle which means its hard for me to determine how much I can give. Basically I get a poof of smoke until the RPMs get up around 2k or so then its smoke free pedal to the metal (if I want).
Leak is around the sending unit where my rear brakes have been spraying.
