Old 08-20-2012, 04:15 PM   #24 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
tang band W8-740P in 17" wide, Bill Fitzmaurice Autotuba(folded horn)... 44lbs total LP at 90hz to 30hz cut-off
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
