Old 08-20-2012, 06:14 PM   #45 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
For my adjustable Grille blocker, used Loctite Marine 2-part Epoxy for the slide stoppers. prep was wiping surface clean, lightly sanding(220grit) both mating surfaces, and squashed together let dry for ~5mins with slight compression.
Tail is looking great taking shape, i dont think it would hurt to have a couple wooden dowel rods connect wall-to-wall, as well some virtical supports toward the middle...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
