Old 08-18-2012, 09:50 PM   #41 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
It's pretty cool that you're mainly making the tail out of coroplast. Do you think that tail will be strong enough to support the weight of snow on top of it?
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
Old 08-18-2012, 09:57 PM   #42 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
brush the snow off
Old 08-18-2012, 10:13 PM   #43 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Snow could be an issue. Coroplast is pretty slickery stuff, but I've seen some awfully sticky snow and ice, too! Only time will tell.
-Terry
Old 08-19-2012, 08:41 AM   #44 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Looking good! I like you edge splints. That approach could help with compound curvature. I haven't worked with Coroplast yet myself. But future projects beg for it. I wondered about gluing previously but never pursued the topic. You super glue mention got me curious enough to start looking. I found these links helpful.
Coroplast - Manufacturer of Corrugated Plastic Sheets
Coroplast - Wikipedia, the free encyclopedia
The Recumbent Bicycle and Human Powered Vehicle Information Center
How to Glue Coroplast | eHow.com
Rock on!
Recreation Engineer
The Following 2 Users Say Thank You to KamperBob For This Useful Post:
MetroMPG (08-20-2012), Tango Charlie (08-19-2012)
Old 08-20-2012, 06:14 PM   #45 (permalink)
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
For my adjustable Grille blocker, used Loctite Marine 2-part Epoxy for the slide stoppers. prep was wiping surface clean, lightly sanding(220grit) both mating surfaces, and squashed together let dry for ~5mins with slight compression.
Tail is looking great taking shape, i dont think it would hurt to have a couple wooden dowel rods connect wall-to-wall, as well some virtical supports toward the middle...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 08-26-2012, 02:22 AM   #46 (permalink)
Deadly Efficient
Earlier this week I installed the trailer harness wiring in the Vibe for the tail lights that will be mounted on the t'ailer's aft bulkhead. But I haven't had a chance to plug in the $26 trailer light set to see if it works.
Since I was busy with other priorities today, I didn't get to work on the t'ailer until after 9 o'clock. Burnin' the midnight oil.
I got the lower left skin on it, though. I accomplished something at least.
Why is it that the closer Labor Day gets, the smaller the steps I get done?
-Terry
Old 08-26-2012, 02:50 AM   #47 (permalink)
wrx4me...
no worries - '91 Subaru legacy L
90 day: 31.45 mpg (US)
weevee - '08 suzuki vstrom dl650
90 day: 61.22 mpg (US)
wrx - '09 Subaru wrx sedan
90 day: 29.8 mpg (US)
Big Bright Green Pleasure Machine - '09 kawasaki ninja 250 se
Connie - '09 kawasaki concours
Nicely done! What percentage improvement do you expect from a boat tail? I'd very much like to see the finished product.
Old 08-26-2012, 09:04 AM   #48 (permalink)
Wiki Mod
if he gets about what my sister car got , he should see about 5MPG at 55MPH.
Old 08-26-2012, 09:31 AM   #49 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Are you going to take off the roof racks? Is your attachment point the single 2" receiver hole.
Noah Webster, 1787
Old 08-26-2012, 11:11 AM   #50 (permalink)
Deadly Efficient
Darin (MetroMPG) saw a 15% improvement when he put his cardboard prototype on his Blackfly. I'm hoping for 10%, since mine is truncated. That would net me almost 4 MPG.
I'd very much like to see the finished product, too!
Yes, the only attachment is the receiver. I drilled and tapped a hole in the bottom of it, and a 1/4-20 bolt tightened against the luggage rack's tongue (is that the proper term? The part that slides into the receiver, anyway.) keeps it from rocking to and fro.
Roof racks will be removed...sometime. It's been on my to-do list forever.
-Terry
