Old 08-20-2012, 11:00 PM   #86 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Here's an updated template overlay with the Kamm and tail extention..
Seems i am a bit off, maybe i was fine with the shallow angled Kamm before i compared to the Prius slope. and i can angle the tail extension up more level to follow more with the template. Maybe its not that big of a deal but i think the car pic is like 1-2degrees off from level? probably not a big difference.
The Red outline shows slightly compromised angles to shorten the boat tail, with the hopes of better attached flow. And an idea of how long it would be if i did it semi proper job
Name:	Kamm template zoom.jpg
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
