Old 06-06-2008, 11:02 PM   #129 (permalink)
ttoyoda
ttoyoda's Avatar
If the float bowl is emptied, it will take 5 to 10 seconds to get the car restarted.. The float bowl will have to be refilled...
I have also decided to place the muffler in the rear tail.. to get some crap from under the car.. this will allow for a cleaner underside in the car and allow me to place the exhaust directly into the slipstream..
If you can increase the size of the muffler and reduce the back pressure of the exhaust system you will increase economy, because you will reduce the pumping loss the engine endures trying to push exhaust gasses out.. There is also a great opportunity to tune the exhaust system for best flow at the RPM you normally drive most of the time.
There is a pressure wave (compression, not transverse) in the exhaust system when the car runs.. the wavelength of the wave depends on the engine rpm. At certain RPMs , the wavelengh is an exact multiple of the lenght of the exhaust pipe. Ideally, you would have the negative (low pressure) part of the wave reflect from the end of the straight section of the exhaust pipe just before the muffler, and come back just in time for the next exhaust valve to open. If you have ever made compression waves in a slinky stretched on the floor you get the idea.
Here are some videos, the first is short, the second is long winded.
Unfortunatly they mostly show transvere waves, but compression waves work the same way.
If you do this you should again watch your plug colors, the engine may run lean with the extra airflow you will get.
