Old 08-22-2012, 11:41 AM   #4 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Why aren't you letting the ScanGauge calculate fuel consumption? Do you have the "fuel type" setting on "hybrid"? That will keep the ScanGauge alive while coasting.
If the ScanGauge is shutting off because of using the key to stop the engine, a kill switch will fix that.
