Originally Posted by t vago
Jó napot kívánok!
All alternators are fairly inefficient. However, lightly loaded alternators are more inefficient than heavily loaded alternators.
The idea behind using a smaller alternator is that a smaller alternator will be driven closer to its maximum rated output power.
If it's possible, you might try to get an ammeter and measure your car's loading. However, with a older diesel, the only significant loads I can think of would be your exterior lighting.
Hi T Vago,
Thanks for your fast answer and for the Hungarian words!!!
