Old 08-23-2012, 05:43 PM   #5 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Metal screen (aluminum?) has been used for belly pan material. You could try that for a season.
I have had snow blow in gaps in the belly pan, melt from the exhaust heat, and re-freeze as ice. Eventually it did thaw and drain without removing the belly pan. Perhaps the rubber air dam could be used year round and the belly pan used in the warmer months?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
