If there is room, you could use a small hose clamp to slide up and tighten. Lets you adjust the height on where you want it at too. Open up a small hose clamp and put it around the rod. Most struts have enough room to leave it on too.
VT247
Originally Posted by HydroJim
Do you think it would be more aerodynamic with the hatch open?
Looks like the struts aren't strong enough to hold it up so I'll have to devise something to hold the hatch up
