Old 08-24-2012, 11:35 PM   #191 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Here are some instructions for a sanding skiff. From Georgi Georgiev
Don't worry about less than 60 grit.
I would add that you should get several tubes of spot filler apply it with a smooth plastic card then sand and fill, spray with flat primer then repeat.
Noah Webster, 1787
The Following User Says Thank You to Varn For This Useful Post:
aerohead (08-25-2012)
