You are going to want to control a fan that big with a relay not a toggle switch.
It would be good to get the whole stock system that controls the fans, possible a two fan system, have them on a thermostat switch , disconnect one of them in the winter, as they have a high amp draw, 10 to 20 amps. They will indeed need a relay.
To clarify, as i was not clear at all.
i was suggesting to grab the whole fan system with its switches ,thermostats and such, you are right, it needs the relays.
