Old 08-26-2012, 03:20 PM   #14 (permalink)
Gealii
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
Originally Posted by euromodder View Post
If it scrapes too much, you can always mount it further aft, then block in the underside between both positions.
I would like to believe its far enough back to not scrape very often. Only worried about the parking deck ramps with it scraping and i would like to say its good, but only time will tell. I never go over speed bumps my luck on routes in the area and with parking spot curbs i always back in if their there
Edit: The air dam does scrape I have found in 2 areas: Parking deck ramps, and some parking lot exits.
I have found if I approach the parking deck ramps slow enough it will not scrape, so the current plan is to put a brace in the middle to help with stability. I also have plans on some coroplast smooth wheel covers.
"The only real mistake is the one from which we learn nothing."
- Henry Ford
