Old 08-25-2012, 08:45 PM   #11 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
thanks i plan on making an upper grill block just behind my grand ams plastic grill to help with warm up and intake temps. Its either gunna be made out of some roofing rubber i got laying around or sheet metal also lying around
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 08-25-2012, 08:49 PM   #12 (permalink)
The Dirty330 Modder
Gealii's Avatar
Originally Posted by nemo View Post
Nice! How much clearance?
it has about 4.5 inches of clearance compared to the 10 inches in the middle to the bumper and 9 inches on the sides to the bumper
- Henry Ford
Old 08-26-2012, 02:25 PM   #13 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
If it scrapes too much, you can always mount it further aft, then block in the underside between both positions.
Old 08-26-2012, 03:20 PM   #14 (permalink)
The Dirty330 Modder
Gealii's Avatar
I would like to believe its far enough back to not scrape very often. Only worried about the parking deck ramps with it scraping and i would like to say its good, but only time will tell. I never go over speed bumps my luck on routes in the area and with parking spot curbs i always back in if their there
Edit: The air dam does scrape I have found in 2 areas: Parking deck ramps, and some parking lot exits.
I have found if I approach the parking deck ramps slow enough it will not scrape, so the current plan is to put a brace in the middle to help with stability. I also have plans on some coroplast smooth wheel covers.
- Henry Ford
Old 09-12-2012, 08:22 PM   #15 (permalink)
The Dirty330 Modder
Gealii's Avatar
I finally went out and got my self a 4x8 sheet of coroplast. So I found it was time to start with a grill block beings I'm about to fill my tank up. I started with the upper grill to more see how I liked working with coro and it seems durable enough to use finally seeing why everyone does use coro.
The left grill is blocked the right side is getting prepared atm.
ID:	11480   Click image for larger version
- Henry Ford
Old 09-12-2012, 10:17 PM   #16 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Nice! Now you just need some black cable ties. Any plans for lower block?
Old 09-12-2012, 10:47 PM   #17 (permalink)
The Dirty330 Modder
Gealii's Avatar
Actually the white zips are not very noticeable I looked from about 10ft away and if I wasn't looking for the zip-tie I wouldn't of noticed it. I am thinking about doing the outside sections of the lower grill if you take a look at the lower grill it is kind of in 3 sections. I got a lot of plans for this especially since when I got the 4x8 sheet I wasn't quite thinking it was going to be that big of a piece
If I can get a name change to this thread it would be helpful to.
- Henry Ford
Old 09-13-2012, 09:19 PM   #18 (permalink)
The Dirty330 Modder
Gealii's Avatar
Well I finished the entire upper grill today and tomorrow I plan on starting on the smooth wheel covers. I have also changed 2 other things; found how to turn the illumination off on my radio without killing it saving a little bit of energy, and I got some more relaxing music saved to flash-drive to listen to, city driving makes me a bit angry so hoping to change that.
- Henry Ford
Old 09-13-2012, 11:39 PM   #19 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
kudos for seeing ALL the issues involved w/ getting better milesge!!!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-19-2012, 08:36 PM   #20 (permalink)
The Dirty330 Modder
Gealii's Avatar
Yea i love having problems this kind of problem solving is my favorite. Well the last couple days my battery has been dying over night finally went and picked up a new battery and found how my intake is ran, I plan on having the cool air blocked to the intake, smooth wheel covers, and the underside por15 painted done by next week
- Henry Ford
grand am air dam
