Old 08-28-2012, 10:43 AM   #19 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Yes, reduce frontal area if you can.
Also, don't forget while you're noodling designs that you want construction that avoids "sharp" corners on front edges. Rounded corners (radius of ~2 inches is enough) are far better (and harder to make ).
EDIT! Don't forget also that the "template" shows profile taper only, but taper should be applied to the sides as well, if possible, with rounded corner/transitions between the top & sides. Side taper is arguably more important than top taper (2 sides, only 1 top).
