Old 08-28-2012, 01:42 PM   #31 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Right now there is a single tension spring at the lower rear of the superstructure,bridging across to the inner face of the wheelhouse radius.
I might add a bungee at the front,as, in Conehead parlance,it's a little 'flopzoidial.'
With only one restraint, I'd put it at the front.
If you can get the front end close to the truck's body, the wind will do the rest.
The Following User Says Thank You to euromodder For This Useful Post:
aerohead (08-28-2012)
