More or less. And, using a butterfly valve on selected intake runners, in order to shut off those cylinders, would be even worse than merely shutting down the injectors for those cylinders. I started work on a similar project for my truck, shortly after joining this board, only to come to the realization that this butterfly valve idea would not work as intended.
