Personally I would get the sprocket and chain, align them perfectly, then from that position make your engine mount. Since I can weld, that's how I would do it, then I would have perfect alignment. You could also slot the bracket to allow for adjustment, but if you are using a motorcycle chassis then it should already have a front to rear adjustment capability.
regards
Mech
