Old 08-28-2012, 05:53 PM   #21 (permalink)
Alright guys, need some advice. I'm about to begin mounting the motor, but I need to know what needs to be bought first. I need to make a custom bracket/frame to hold the motor in place to the motorcycle frame. Should I get the sprocket for the motor first and then the chain so I know how it'll fit in place? Or should I mount it and worry about sprocket and chain after?
Old 08-28-2012, 06:07 PM   #22 (permalink)
Personally I would get the sprocket and chain, align them perfectly, then from that position make your engine mount. Since I can weld, that's how I would do it, then I would have perfect alignment. You could also slot the bracket to allow for adjustment, but if you are using a motorcycle chassis then it should already have a front to rear adjustment capability.
regards
Mech
Old 08-28-2012, 06:11 PM   #23 (permalink)
regards
Mech
I can change the chain tension by moving the rear wheel forward or backward. I already have a website in mind that has the sprocket, but I have 2 questions before I purchase.
1: What size of sprocket should I get (number of teeth) for the motor? I'm looking at getting up to 65-70 MPH with this bike and wand a good gear ration to support that.
2: Can you even purchase chains with removable links anymore? I'm not seeing any for sale. Or maybe I'm just looking at the wrong vendors.
-edit-
I was able to do some more research finally and it seems a 4.5:1 ration is standard, but if you want faster acceleration and faster speeds, 8:1 is what people are using. So I think I'll look in the range of 6:1 or 6.5:1.
Old 08-29-2012, 05:32 PM   #24 (permalink)
I'm posting more parts and parts sources so others know what to get and where to buy it.
Looking to start with a 16 tooth gear for the motor. I'm thinking of this one here.
For the wheel, I'm looking at an 80 tooth sprocket. I haven't done any measurements for the rear wheel yet, so I don't know the exact gear I'll get. I need to get the diameter of the bore first.
Old 09-16-2012, 03:54 PM   #25 (permalink)
Alright guys. Sorry for the flood of triple posts. I need some help. I got the motor in and I've been trying to custom fabricate a very simple mounting plate. Does anyone know of a shop that sells generic mounting plates for the ME0913 motor? I'm looking for a generic plate that I can then weld or bolt onto my bike frame, so it doesn't need to be custom fit or anything. I find that at this point in the project I am lacking the proper tools to cut and drill all of the metals.
Old 09-16-2012, 05:52 PM   #26 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
this company sells motorcycle kits; fabrication required
hub motor, brushless motor, brushless dc motor, BLDC motor, bike conversion kit, brushless controller,brushless motor controller,electric bike,wheelchair controller,electric car motor,brushless joystick controller,electric outboard conversion
good forum for electric vehicles
Endless-sphere.com • Index page
Old 01-23-2013, 05:18 PM   #27 (permalink)
Alright guys. Got my welder and I'm about to mount the motor, but I've run into a problem finding the sprockets I need. I decided to go with a 6.5:1 ratio, meaning a 14 tooth sprocket on the motor and a 72 tooth sprocket on the wheel. However, I'm having trouble finding a vendor who sells 72 tooth sprockets.
Do anyone have any vendors in mind for 72 tooth (or maybe 128 tooth?) sprockets? I should mention that I have found some sites that sell 72 tooth, but they're like $80 a pop.
On to my second issue, the controller. Can you guys do me a favor and keep your eyes/ears out for a used controller? Maybe one from another project that has been abandoned? I'm looking for a reasonably priced controller that's below the $300 mark.
