Old 08-28-2012, 09:49 PM   #18 (permalink)
svt98t
Neutral is my favorite
The Black Pearl - '03 Mercury Marauder 300A
Team Panther
Land Yacht - '08 Lincoln Navigator L Ultimate
90 day: 15.89 mpg (US)
Tank of Justice III - '97 Ford Crown Victoria HPP
Team Panther
90 day: 24.84 mpg (US)
Many people have put manual transmissions in Panthers. It just takes a bit of work.
Many opt for the T-45 from the Mustangs because of availablilty. I'd like the T-56 because it has 6 speeds and I could score one for relatively cheap from my cousin.
I am aware the the front end may come up a bit. Taking 120+ lbs out of it might do that. Idealy, I would do the block swap and trans swap, and then see how the car looks/ handles. If I have to lower it, change the rate of the springs and shocks, then so be it. Lowering and a bit stiffer suspension helps with FE.
But as of now, the block swap is a sure thing.
-ryan s.
1997 Ford Crown Victoria HPP- "Tank of Justice III" 194k - 578.9 miles on ONE tank
2003 Mercury Marauder- 63k, not so fuel efficient; #1,548 of 11,052
2008 Lincoln Navigator L - 244k (don't ask about mpg)
