Old 08-28-2012, 10:04 PM   #15 (permalink)
metromizer
Originally Posted by serialk11r View Post
metromizer, thanks for the advice.
I did register at spyderchat.com and make a post
if you do, be sure to have your Big-Boy Pants on... that place can get a little rough... particularly if you think even slightly outside the box, are new, and young.
They all tell me to gut the precats, because they're notorious for blowing, and then sending ceramic dust into the engine which destroys the cylinder bore.
I read that as well. I pulled my exhaust manifold off 6 months after getting my Spyder, at 130kmiles. Surprisingly the honeycomb was 100% perfect and in tact, but I chipped it out per the advice. It was burning some oil at the time, and has only gotten worse with wear. In my case, the pre-cats had no effect on my engine wear. But even with that, it still passes a SF Bay Area rolling dyno emissions test. For now at least.
I expect to be putting at most 1500 miles a year on the car, at least for now, so the gear swap isn't so economically sound.
I agree. Good luck!
