Old 08-29-2012, 05:08 AM   #36 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by basjoos View Post
I ended up switching to fairly stout spring as the weaker springs that I initially started with allowed the covers to oscillate at speeds over 70mph.
Phil will be doing 130+ mph ...
The Bonneville run is straight with minimal steering once lined up.
How about fixing the covers during the run ?
Some tie wraps could do the job.
And a cutter to remove them again after the run.
The Following User Says Thank You to euromodder For This Useful Post:
aerohead (08-29-2012)
