Originally Posted by California98Civic
Hello! The template is not lined up properly yet. Find the highest point in the roof line and match it to the template's high point. This might mean that the template "line" will track through your cars aft roofline.
Hi, thanks for your useful input!
As euromodder alludes to, the touring roofline is basically flat, and provides carrying capacity I find useful
therefore I tried to line up the template to retain the space, but look at how the template would indicate possible rear treatment for better aero..does that make sense?
Here's another photo, I'd be interested to see where you'd position the template- please have a go
Undertrays get wide support here. Mirror deletes are more debatable. Grill blocks are good (keep an eye on temps. Make sure your early efforts at mods are completely reversible... you'll want a redo sometimes and you don't want to have drill holes all over the body!
I have the undertray off an e46 at my unit that I can butcher a bit to make it fit..
I wouldnt be deleting the miirors, jsut trying to reduce the frontal area a touch.
I'm hearing you re the " reversible"- the upper grills pull out easily-so even when blocked, I can clear them quickly
