Old 08-29-2012, 11:58 AM   #21 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
Originally Posted by HydroJim View Post
I assume the OP didn't follow the template from the top of the roof for visibility reasons but I would say it's still pretty effective because it runs back into the template later.
Even if he shortened the tail about a foot(cutting off of the front mounted section) he could preserve more of the "template" tapper. Keeping the same small footprint of the rear where the lights are mounted. While still not interferring with rear visability.
Screwing in Wooden Dowel Rods to the inside of the tail vertically, could help create a skelton inside not allowing the lengthy coroplast (sag), creating the steep angle just behind the window, as is.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
