Originally Posted by Ultra-Orange
[IMG]Not sure on the HP, Just a honda gy6 150cc motor. initial acceleration is pretty snappy but gets kinda wheezy about 40mph, handles hills well at sub 45 mph. Top end the motor really runs out of power.
Found this: GY6 engine - Wikipedia, the free encyclopedia
Do the RPMs seem abnormally high for cruising above 40+? Wiki mentions its driven commonly with CV type carbs, this could be the reason why. CV carbs if not tuned properly could have demenishing performance results in the higher rpm range. luckily main jets are a snap to change out for better tunning
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
