Old 08-31-2012, 04:58 PM   #36 (permalink)
ChazInMT
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Originally Posted by Susanne View Post
Well - if the adminstrator chooses to remove my link to research, but leave up another's link to testimonials, there is not much I can do to show more.
Susanne,
Go find a Hill that is steep enough for you to reach ≈50MPH over 1/4 to 3/4 mile, start coasting your car down it by either A) releasing the break at a start point, or B) be going a certain speed when you pass a start point (5-10mph).
Coast down the hill and either A) measure the speed you're going when you pass another landmark, or B) Measure how long it takes to get to your 50MPH to Stop your timed/measured distance run.
Now Put your GasPods by AeroHance (I try to mention that as much as possible to bump the Google rating of this thread BTW) on your car, and repeat the process, use 2 or 3 different cars, do this 3 to 4 times with each car. Alternating GasPods On/GasPods Off. Once you get the hang of it, you’ll have a trial done every 5 - 10 minutes. Best if it’s a calm day. Inflate the tires on the cars to at least 40psi for the test. Within a few hours of testing this way, you'll have quantifiable results that show whether GasPods © by AeroHance ™ really work or not.
It’s clear that if you have the GasPods on, and it takes less time to reach 50MPH, or you are going faster when you pass your end point, then the GasPods are working.
So in the amount of time you have spent typing your posts in here and reading (I really hope you did read what we're trying to say here) our posts, you could have wrapped this up.
And here's the best part......I bet you MetroMPGs solid wheel covers, that if you came here with the raw data, there are folks in here who would kill each other for the opportunity to analyze it for you and tell you to the nearest 2 decimal places exactly what the numbers mean. Cause that's just the kinda people there are around here.
So, you say there's not much more you can do?
I think not.
(Unless as I posted previously you already did this and it shows practically no difference)
The Following User Says Thank You to ChazInMT For This Useful Post:
UltArc (11-07-2012)
