Your fuel log is headed in the right direction
Originally Posted by maczo
Sooo... is around 10 deg deviation from the roofline an acceptable amount?
A 10°, or even 12-14°, angle
from horizontal is good, but adding that to your roof's slope may be too much. Also, what you need is a smoother transition between roofline and Kammback.
Make a template of the transition with the correct angles and tape it to a level ruler:
BTW, have you considered an MPGuino or other instrumentation?
Originally Posted by euromodder
Next target : under 6L/100 km (over 39mpg) or a more ambitious under 5L/100km (over 47mpg) ?
For such a small car, both should be possible.
Remember that the small car has a huge (for it) engine under its hood - Seicentos came with a 900 or 1100 cm3 engine, Maczo squeezed a 1200cm3 engine with almost twice the power of the original
