Old 09-01-2012, 09:02 PM   #43 (permalink)
eco_generator
AeroGuy
eco_generator's Avatar
Outback 14 - '14 Subaru Outback Limited
90 day: 23.1 mpg (US)
I was running some math and .1 gal is a severe penalty for cars that get higher gas mileage. Taken to extremes I could bring a semi that gets 4 mpg and come in 15 minutes late and it knocks down my percentage above EPA by only a bit.
With a little more calculation I figured out that taking off the % over directly affects both equally. Every minute deducting 2% off your epa overage works out better. Maybe 3% to shun over-timing it for even more gain. 2% means you need 3-4 mpg more to cancel 5 minute penalty. Even if the percentage penalty is set higher, I think it makes way more sense than gallon based penalties.
And can you list the date clearly in the first post? I know it's around, but it'd be much more clear with it listed with the other links and info. Thanks!
