Old 09-02-2012, 05:26 PM   #6 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Properly done, P&G and clutch starting is no harder on the clutch than normal shifting.
Check basjoos' Aerocivic thread - he's got several hundred thousand miles on his original clutch, if I'm not mistaken, and he uses P&G (or did in the past, before his lean-burn engine swap).
And to add to what Metro said, I do a lot of P&G with the motorcycle clutch, and it still works normally, and the bike has 125,000 on the original plates.
It sounds like the clutch is simply worn and needs replacing.
Jim.
