Old 09-03-2012, 10:49 AM   #12 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Max, thanks for starting this thread. Hope you don't mind I fleshed out your thread title to make it more descriptive & attract more eyeballs.
I think you will find that the members who have made & tested undertrays with flat materials have found improvements for the reason you stated:
it may improve a little bit over the pumpkin and other bits that hang from the bottom of your car
So I think it's important not to throw out the easy-to-construct baby with the optimally-designed bathwater.
For that reason, I'm glad to see you tempered your language from the earlier assertion in other threads that a "flat belly pan is no good" to a flat belly pan isn't going to do as much good as one with these optimal design properties (paraphrasing).
MTrenk (09-04-2012)
